it keeps dieing
Old Apr 2, 2010 | 01:56 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
it keeps dieing
well i have a 350 TBI backed by a 700r4. now recently i replaced the o2 censor bc so much gas kept getting dumped in it would stall out after start up. but since i replaced it my check engine lite is off but now it runs crappy, im not talking crappy over time im talking like a flip of a switch. i figured it needed a tune up (havent got to it yet) but now today its just dieing. the idle is kinda rough and low(since o2 replace). and it just for the 1st time cut off while driving (instead of sitting at a stop light) but every time it shuts off it starts right back up. it doesnt always die, and infact it just started a few days ago. ideas? questions? tests? plz help this is my dd and i cant have this happening.
Old Apr 2, 2010 | 03:09 PM
darkness878's Avatar
Car: 1987 iroc z camaro
Transmission: 700 r4
Axle/Gears: no idea
Re: it keeps dieing
i have the same problem is it ideling at like 15 and like straight **** ?
Old Apr 2, 2010 | 05:30 PM
Fuzzman17's Avatar
Car: 92RS
Engine: 305 TBI
Transmission: 700
Re: it keeps dieing
DARKmj16, I would start by checking your plugs. A rich mixture burns more easily than a lean mixture. If your plugs are fouled then you could have picked up a missfire when you corrected the mixture. Likely not your only problem but it's a place to start.
Old Apr 3, 2010 | 03:29 AM
DARKmj16's Avatar
Engine: 305 tbi
Re: it keeps dieing
its idleing at 550 and like striaght s***
ok would help explain the idleing but any one got ideas on why it keeps dieing out of the blue?
Old Apr 3, 2010 | 12:29 PM
Axle/Gears: no idea
Re: it keeps dieing
i turned my idle up i think i have a vacume probkem cause when i pull both of the hoses out it idles fine then when it goes back to normal it idles real rough and shakes alot
Old Apr 3, 2010 | 02:02 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: it keeps dieing
mines doesnt really shake to bad it just idles crappy but it idled fine before the o2 replacement.
Fanatic1074
Oct 3, 2022 05:57 AM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
