replacement starter soleniod wire question
Old Apr 4, 2010 | 03:57 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
replacing engine in my gta..
got everything mounted up and wired up.
I had to replace the starter solenoid because I broke the orginal one..
anyways the replacement one has a spot for a big wire and 2 sport for a little wire. My stock one only has 1 spot for a little wire..
I hooked it up and it doesnt do anything when I turn the key now..
Is this the wrong solenoid or do I probly have somethign else off?
Anyone know why the aftermarket one would have 2 places for a little wire?
thanks
Old Apr 4, 2010 | 04:19 PM
bcmag's Avatar
Re: replacement starter soleniod wire question
hooked wire up to wrong small post.should be labeled "s" and "I".you want to use s terminal.this is a generic solenoid that will als work on older cars with points ignition.hook up to s and you should be fine.
Old Apr 4, 2010 | 05:48 PM
wannafbody's Avatar
Car: 88 GTA
hmmm I hooked up to the other post and still nothing...
I got 3 wires running to the big terminal and 1 wire running to the small terminal.
am I missing something
Old Apr 4, 2010 | 09:59 PM
wannafbody's Avatar
Car: 88 GTA
anyone have a wiring digrham?
Old Apr 4, 2010 | 10:13 PM
wannafbody's Avatar
Car: 88 GTA
I guess it helps if you put it in park!!!!!
Running great now!!! lol
thanks
Old Apr 4, 2010 | 10:28 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Good catch...
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
92projectcamaro
Aug 6, 2015 01:20 PM
