power steering pump replace or rebuild?
Old Apr 5, 2010 | 11:27 AM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
I'm in the process of cleaning up all the accessories to bolt back up to my engine and wondering if I should buy a rebuild kit or just buy a whole new pump and reservoir. The rebuild kit is $14 and the whole new pump and reservoir is $47. Any suggestions?
Also, why is it so bad to use a 3 jaw puller to remove the power steering pulley? Thats what I used and had no apparent problems.
Thanks!
Old Apr 18, 2010 | 09:20 PM
mgilorma's Avatar
Car: 90 RS
Re: power steering pump replace or rebuild?
I decided to just go with the rebuild kit, came with all new o-rings and seals, was pretty easy to do.
When I got everything put back together I found out why you shouldn't use a three jaw puller, apparently it can bend the pulley! With some pursuasion I got it all straightened out.
Old Apr 18, 2010 | 09:35 PM
Damon's Avatar
Yeah, they make a special puller just for GM pump pulleys. Clamps on the groove in the pulley hub and gets a hellacious bit on it, too. Install tool is also very handy to have to put it back together (and is a totally different tool from the puller).
Congrats on a successful rebuild. More than I would have tackled. I would have advised spending the extra bucks on a complete unit.
You should consider a how-to write up on the pump rebuild. Sounds simple enough that most could do it, but scary enough most wouldn't try.
Old Apr 19, 2010 | 12:39 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
did the rebuild kit come with bearings for the PS pump?
on my PS pump, I think the bearings are going, got a small bit of in-out movement on the pulley.
Old Apr 19, 2010 | 07:14 AM
mgilorma's Avatar
Car: 90 RS
No, it didn't come with any bearings. The reason I rebuilt mine was because it was leaking ps fluid and looked terrible.
Old Apr 26, 2010 | 11:02 AM
mgilorma's Avatar
Car: 90 RS
to answer my own question about why NOT to use a three jaw puller, see:
https://www.thirdgen.org/forums/tech...ulley-way.html
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
justin57
Aug 20, 2015 07:05 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
