Zero Compression on #2
Old Apr 5, 2010 | 12:27 PM
jeremyzpoor1990's Avatar
Car: 1990 Camaro RS 3.1
New to posting, but I absolutly love this forum!
I have a 1990 RS V6 3.1 and zero compression in my number 2 cylinder. (I overheated it bad last week and it blew off the bottow radiator hose at the engine) No other water leaks that I saw, I ran the car a few times around town to get a couple of tools and still nothing. Did a compression test and all were good except #2 was zilch! Ugh....
I have pulled the heads out thinking it would be a head gasket or a valve. No breaks or signs of leakage in the head gasket that I can see. Will pull the valves out next to check them out.
Question is... what else should I be looking for?
Thanks for the help!
Old Apr 5, 2010 | 12:35 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Zero Compression on #2
well since you pulled the heads out, how about pouring some thin oil into that cylinder and see if it seeps through... if it does, then diagnose no more...
You weren't using synthetic, were you?
Old Apr 5, 2010 | 12:38 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
Based on your description of events leading up to the issue I would concentrate on the rings. Severe overheating can burn the rings to the point significant blow-by causing no compression.
Unfortunately you've already disassembled the motor. Prior to doing that I would have determined where the compression was leaking from. Through the intake, you have a valve issue. Through the valve covers, you have a ring issue ect... Along with the rings, I would make sure the heads are still true. Excessive heat can warp heads to the point that they will not seal.
Did you by chance do a compression check on all of the cylinders? What numbers did you get? Typically a wrapped head will show itself on more than one cylinder but stranger things have happened...
Old Apr 5, 2010 | 02:36 PM
nope, no synthetic, i'll give this a try first since its easy and harmless, thanks!
Old Apr 5, 2010 | 02:41 PM
i did check all of the cylinders, all were the same but #2 was a dead dog, i forget the reading, i have it written down here somewhere and it matched up with what others were sayiong was generally good
Old Apr 5, 2010 | 02:43 PM
all check out on compression at +/- 2 of 135
Old Apr 5, 2010 | 04:31 PM
Heads are straight and true, just checked. Guess I will be pulling the bottom to check the rings. Any advice for that?
Old Apr 5, 2010 | 08:37 PM
Pocket's Avatar
Car: 91 Trans Am
Grab a new engine with a warranty from the pull-a-part on Patterson Ave. 3.1's a plenty and no rebuild cost
For a common V6/V8, replacement is the cheapest route when you get bottom end problems
Old Apr 5, 2010 | 08:45 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
yeah use this as an excuse to drop in a 350 or 383 in there...
Old Apr 6, 2010 | 01:33 PM
good idea, and thanks! too bad i am in texas right now he heh
Old Apr 6, 2010 | 02:46 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
If you're willing to go to a bit of added expense and effort, I agree with this entirely. Will need to change fuel system and a buncha other stuff, but hey, you're pulling the motor already...
Old Apr 6, 2010 | 03:04 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
If one cylinder had a compression issue and all of the other cylinders were ok it really points to a head issue. I'd be very careful in inspecting the valves and combustion chamber of the cylinder in question. If you don't find any issues on the bottom end, get the head magnufluxed.
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
