Turns Over No Start!! Please Help
Old Apr 6, 2010 | 05:27 PM
edz88irocz28's Avatar
Car: 1988 Iroc-Z28
Engine: TBI 305 Bored 30 over mild Mods
Axle/Gears: Stock
Hello All,
I am posting this thread for some help I have searched for possiable problems related to what I am having but do not seem to find any info. Recently I have had trouble with starting my camaro It's a 88 Iroc with 305 TBI automatic. I took it to the shop and they replaced the whole tank with new pump and sending unit, they also replaced the fuel filter. The whole system had rust and they also cleaned the lines down to the injectors. So car ran fine for a couple of weeks I was doing some minor fixes as it sat in my driveway, Batteryu ran down due to the notorious trunk hatch motor problems. I picked up a new hatch unit and cluster at a swap meet put the items on and it no longer would start. I checked down the throttle body and fuel is going in I am also getting good spark to the #1 spark plug. The car just turns over and over I have checked all the fuses under the dash and all seem good I do not think it is related to the fuel system maybe a sensor not allowing it to turn on? My shifter does not stay in park to well but even when I put it in neutral it does not turn on? Any suggestions on where to go from here? Really need help I have to get in running and registered home onwers assoc. is bugging about my car in driveway I do not want them to tow it and I have no place to put my car..
Ed
Old Apr 6, 2010 | 07:03 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
Re: Turns Over No Start!! Please Help
check your neutral safety switch had that problem with my old 88 firebird.
Old Apr 6, 2010 | 11:32 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Ditto.
Jim Berry
Old Apr 6, 2010 | 11:51 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Originally Posted by edz88irocz28
Hello All,
Ed
have you check ur VATS that might cause the motor tu turn but the ecm wont send pulse to injectors... also it my be the cluster you got is not like the one u had...u might thing what does the cluster has to do with the engine. Well i thought og the same thing but i found out that MY car wont start if the cluster is not installed i tried it different times..
Old Apr 13, 2010 | 05:42 PM
Car: 1988 Iroc-Z28
Axle/Gears: Stock
Thanks to all that replied to my post. I have since changed the NSS with one I got off ebay that came with another shifter(USED) I have since gotten the car to start. It starts up and is running horriable. I have two codes that popped up code 15 and 54 I know what these codes mean I have to check the coolant temp sesnor the part is new but it is from autozone, should I change the thermostat? On the 54 code it says fuel pump circuit but what could cause this I had the who.le sustem done at a shop, would the code 15 set this off?
Thanks in advance for anyone's input.
Ed
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
