1.6 stamped steel rockers->comp 1.6 pro magnums
Old Apr 9, 2010 | 01:30 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
The big question is:do I need new pushrods?Is there difference at valvetrain geometry?
Old Apr 9, 2010 | 07:01 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 1.6 stamped steel rockers->comp 1.6 pro magnums
I can't see it. It can't hurt to check, but it'd surprise me if there was any new issue.
Old Apr 10, 2010 | 11:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The Comp Pro Magnum RR's require longer studs.
RBob.
Old Apr 11, 2010 | 08:15 AM
z 28 jari's Avatar
Engine: 385
RBob.
Do you know how long?
Old Apr 11, 2010 | 08:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
With any change of valve train components you should always measure to ensure you have correct pushrod length to get proper rocker engagement on valve stem
Not all engines the same
Old Apr 11, 2010 | 02:49 PM
z 28 jari's Avatar
Engine: 385
I will check with marking colour that roller tip is middle of valve stem.
When I measured overal stud height it was 1.7".
I measured also how much there is visible thread at stud when valve is cloced.At top of stud to top of trunion distance is 0.366".Is this too short?
If it is too short is ARP #134-7104 right stud to pro magnums?Those ARP studs have overal stud height 1.896".
Old Apr 11, 2010 | 06:11 PM
F-Body Demon's Avatar
DO NOT BUY CHEAP EBAY ROCKERS!!! I just bought a set and it was junk $110 WASTED! Do yourself a favor and go up a notch to at least the cheap brand name stuff, an extra $100 is cheap insurance for causing problems in your engine!
Old Apr 14, 2010 | 01:03 PM
z 28 jari's Avatar
Engine: 385
Valvetrain geometry is cheked now.Seems that I need to buy shorter pushrods.Current ones are 7.18" overall lenght (5/16 diameter),and wear mark at valvetip is not coplety centered.
With adjustable pushrod(adjusted to 7.1") wear mark is centered.
Any recomendations what brand,material,hardened or not etc. should I buy?
Old Apr 14, 2010 | 02:06 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
if your running guide plates then you need hardened pushrods the rest depends on the lift of the cam and the spring pressure
if its an aftermarket cam go with their recomended pushrods if possible cheap alternative is summit pushrods on the cheaper side and still hold up pretty good
Old Apr 14, 2010 | 02:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I have stamped steel roller tip Elgins in the 350 in Berlinetta #1, and have had Magnums in the 396 in the '57 since 1997. I didn't have to change pushrods with either one.
I just installed Ultra Pro Magnums in the 396, which include poly locks. No valve train geometry problems, same pushrods, same rocker studs.
Old Apr 14, 2010 | 02:36 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i'm rather suprised at some of the response . i have comp cams roller tip 1.6 ratio on my car now . pn# 1416-16 , they are not the first set i have used . no problem with stock pushrods if you have the same pn# . good luck .
Old Apr 14, 2010 | 03:14 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I used Crane studs # 99157, which IIRC is a BBC stud. It is 7/16" top & bottom. Used guide plates and a hardened washer under the plate. The washer was required as the threaded portion that goes into the head was a tad too long.
This put the top portion of the stud at 1.81" in length. The stud being 1.76" and the washer being about another 1/16".
I would say that the 0.366" is borderline for a 3/8" stud. And not enough for a 7/16" stud.
RBob.
no green
Jan 9, 2016 09:22 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
