LB9 No spark
Old Apr 9, 2010 | 04:48 PM
massaku's Avatar
Car: 84 15th anniversary Trans Am
Engine: 305 H.O. L69
LB9 No spark
Ugh I am having a spark problem with my car. I replaced the coil, pick up coil, rotor, cap and ignition module. I still dont have anything. its an 89 Trans am and its been sitting for a while. Any suggestions would be appreciated.
Old Apr 9, 2010 | 05:23 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: LB9 No spark
Ignition module
Old Apr 9, 2010 | 07:38 PM
massaku's Avatar
Re: LB9 No spark
Originally Posted by sonjaab
Ignition module
I forgot to mention I replaced that too.
Old Apr 10, 2010 | 12:36 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: LB9 No spark
Hello massaku!!
You actually did mention that you replaced the ignition module, see above!!
Having replaced all that stuff, did you check to see if you are actually getting any voltage to these items????
No power, no spark, no matter how new the items are!!
Old Apr 10, 2010 | 01:38 AM
massaku's Avatar
Re: LB9 No spark
Originally Posted by 87IROC-DAN61
Hello massaku!!
Thanks for the reply!
I have power to the coil and from the coil to the control module.
I dont really know how to test anything else so some advice would be helpful. I am getting gas because the #1 plug is wet with gas. I am really stumped with all of this.
Old Apr 10, 2010 | 02:18 AM
Re: LB9 No spark
Hello massaku!!
Did you put the dielectric grease under the ignition module!!!!
Old Apr 10, 2010 | 02:37 AM
massaku's Avatar
Re: LB9 No spark
Hello massaku!!
Yes I always make sure not to forget.
Old Apr 10, 2010 | 11:07 PM
massaku's Avatar
Re: LB9 No spark
I am going to replace the spark plugs and do a oil change because the oil smells like gas...hopefully something happens
Old Apr 11, 2010 | 05:01 PM
massaku's Avatar
Re: LB9 No spark
heh...spark plugs and oil didnt do anything... plus the starter died. I am seriously thinking about just spending the money for a mechanic...I hope this damn thing drives straight.
Old Apr 11, 2010 | 08:40 PM
massaku's Avatar
Re: LB9 No spark
Pulled the starter... and the wiring seemed funky to me.
There were a couple of wires going to the main bolt on the solenoid
then there was 1 going to one of the smaller posts right next to it.
there are two posts smaller posts isnt there supposed to be another wire going to the other one?
Old Apr 13, 2010 | 02:02 AM
massaku's Avatar
Re: LB9 No spark
Had a friend come over today and determined that I have spark so I guess I have a fuel delivery problem now...
Old Apr 20, 2010 | 11:32 AM
respin's Avatar
Re: LB9 No spark
Hey how did your friend do the spark test? I'm having the same problem with my 1992 camaro. I bought an inline spark tester. still no spark.
Old Apr 20, 2010 | 03:07 PM
massaku's Avatar
Re: LB9 No spark
What we did is just put the spark wire boot close to a piece of metal and
look for sparks. If you have replaced everything that i did check your base timing... After I put it on time my car started.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
