Trans Am Headlights Wont Come Up
Old Apr 10, 2010 | 02:30 PM
dredre08's Avatar
Car: 1986 Trans Am/1988 Camaro Iroc-Z
Engine: 305 TPI/350 TPI
Ok I have a 86 T/A TPI, the problem is my headlights wont come up when I turn them on, I checked to see if the motors work by wiring each motor to my battery, when I did the driver side the light came up, but when i did the passenger side it did not come up but the **** you use to bring them up manually just started spinning for a sec, also when I bring them up manually while the car is on then turn the car & headlights off the passenger side light goes down but the Drivers side stays up..... Does anyone know what the problem is???? Does it sound like I need new headlight motors or is something wired wrong???? and if something is wired wrong does anyone know how to fix it???
Old Apr 10, 2010 | 09:10 PM
Vader's Avatar
Re: Trans Am Headlights Wont Come Up
Verify that the circuits are getting the correct power from both the isolation relay and headlight motor actuation relays. Your '86 uses the older scheme with three relays, just like my '86.
Old Apr 10, 2010 | 09:51 PM
Stephen's Avatar
Car: 87 GTA
If that one **** is spinning, but the headlight won't come up.....
http://www.top-downsolutions.com/pro...roducts_id=118
As for the other one working only if you power it directly, this is probably "broken (short inside) on your car......
http://www.top-downsolutions.com/pro...roducts_id=138
1992 Trans Am
May 10, 2023 07:19 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
The_Phoenix
Feb 4, 2016 07:10 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
