How many starter shims is too much
Old Apr 13, 2010 | 07:45 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
So the deal is, I am finishing up the fresh rebuild of the 350. Basic machine work ie; hone and such. Now I have the starter back on to ops check the rotating assy and pump up the oil, and it take 1/2 inch worth of washers to keep the flywheel away from the starter snout, and forget about the gear mesh. Suffice to say, it spins over nicely now, but damn me thinks something is amiss...... Anyone?
t/y
Old Apr 13, 2010 | 07:58 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: How many starter shims is too much
Do you have the right flywheel for your application? What starter?
Old Apr 13, 2010 | 08:09 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
seems you're using a 14", 168-tooth flywheel, but your starter is for a 12.75", 153-tooth flywheel. Change the starter before you damage something.
Old Apr 13, 2010 | 08:14 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Or the flywheel if your using a stock thirdgen bellhousing.
Old Apr 13, 2010 | 08:44 PM
Huh, ok, the flywheel is the 14088646 lightweight one. The starter is a CSK bought AUTOLIGHT 6316MS. It seemed to work well for the 2 years I had it running, but then again that was 2 years ago, and my memory can be crap at times. The motor is an '89 5.7 and t-5 setup.Thanks
Old Apr 14, 2010 | 07:52 PM
Anyone?
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
