Crankshaft Corrosion
Old Apr 16, 2010 | 08:36 AM
wyatt's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: V8 305 TBI
Axle/Gears: Torsen Rear 3.42
Hey guys,
I have a 350 Crankshaft that had dried oil down the middle of every main journal. This is most likely because of the bottom main bearing having that groove down the middle and this engine sitting for such a long time. Anyway, I bought some 2000 grit sandpaper and knocked all the oil off. The journals aren't completely shiny though. Now the problem, on the front journal, just in the center when a big clump of dried oil was, there are pits or small grooves in the journal. I'm guessing the oil corroded the middle in the years it was sittings. Is the crank still good with the pits just being right in the center where that groove is on the main bearings? The sides of the journals are good and the pits don't have sharp edges. I don't really want to turn it but will it need to be? Let me know what you think.
Wyatt
Old Apr 16, 2010 | 10:50 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Crankshaft Corrosion
First, lightly go over it with a scotch brite pad. Go the way the crank turns, not front to back, across the journal. Second, get us some good pics.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Elephantismo
Feb 13, 2019 12:51 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
sahlomonic
Sep 20, 2015 07:15 PM
