Spark plug size (did I get this wrong?)
Old Apr 16, 2010 | 09:59 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
So I went to the auto parts store the other day and requested AC Delco R45TS plugs to replace the ones already in the car. While swapping them out I have noticed that the new plugs are a little bit longer than the ones I pulled out. Would there be a difference in plugs if they were for aluminum heads rather than cast iron?
I attached pics of the plug comparison, along with a shot of the IROC just for kicks.
Attached Thumbnails Spark plug size (did I get this wrong?)-spark-plugs-002.jpg   Spark plug size (did I get this wrong?)-spark-plugs-001.jpg
Old Apr 16, 2010 | 10:12 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Spark plug size (did I get this wrong?)
Lets start by decoding the plugs. The 45 is the heat range, these are pretty hot. The TS is for extended tip.
These are correct for iron heads. If you have aluminum Corvette heads, you should start with RC12YC plugs.
If you've done cam and headers and so on, iron heads should consider R44TS, aluminum I'm not sure.
Old Apr 16, 2010 | 10:17 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Thanks for the reply, the only reason I bought these plugs is because I couldn't decide whether or not to buy E-3's. The only thing I have added as of today is an MSD 6A, and coil, other than a chip, cat back, and air foil, its pretty much stock.
Old Apr 16, 2010 | 10:29 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I don't think you need colder plugs with that combo. I don't think you'll find any benefit from E3s either.
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
