Power Steering Pump Help
Old Apr 17, 2010 | 09:38 AM
Pug89's Avatar
Car: 1989 Pontiac GTA
Engine: 5.7 TPI L98
Transmission: 700 R4
Axle/Gears: Not Sure
I am trying to take the power steering pump out of a 1989 GTA with the 5.7 350 in it. I have the chilton and the haynes manual but one says remove the pulley first the other says not to remove the pulley first. I can see at least one bolt that has to come off. Can anybody help how does this come off and are any special tools needed.
Old Apr 17, 2010 | 11:46 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Power Steering Pump Help
I find it easier to just remove the whole bracket at the same time. I've never gotten the pulley off the pump, nor have I ever gotten the pump free from the bracket. I just pretend that that is the way it must be, the only way it can be, and move on to "more important" (to me) things.
Old Apr 17, 2010 | 04:36 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Borrow a special tool for this type of pulley from a parts store. My tool has a bearing nut which most pullers do no not. To use an impact wrench as in the video you'll need to remove the entire accessory bracket because the pumps bolts are not accessible until the pulley is removed.
http://www.youtube.com/watch?v=8pxK8fRsNMM
Old Apr 19, 2010 | 07:50 AM
Pug89's Avatar
Engine: 5.7 TPI L98
Thanks for the help. I bought a 10 pulley puller from Harbor freight and after a little muscle it came off. It was a bit of a pain.
Old Apr 21, 2010 | 09:16 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Unless it came off rather easily, See this video the 10 pulley puller has warped the pulley that's why a puller that pulls at the hub is required.
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
