Any tips?
Old Apr 20, 2010 | 01:38 PM
russlavoie's Avatar
Any tips?
i have the motor apart pretty much all the valve covers off and the intake manifold and all the belts. I was wondering if their is anything i should do before i put everything back together. I painted the valve covers and intake manifold black with some high temp paint already and im doing the mounts and water pump and the motor black but i was wondering if their is anything i should do while the motor is already apart. Check anything replace anything let me know thanks!
Old Apr 20, 2010 | 03:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Exactly what engine (year, size, induction type), and why did you take it apart?
Old Apr 20, 2010 | 05:40 PM
russlavoie's Avatar
Re: Any tips?
87 305 thats carburated and i took it apart because one of the push rods were bent. Im having them checked out before i but the valve covers on but if theirs anything else id like to do it before i put it all together
Old Apr 21, 2010 | 01:30 PM
russlavoie's Avatar
Re: Any tips?
i put the push rod in today but it seems as though its sitting to high. The lifter is sitting higher though so im not sure if its the wrong push rod or its just the lifter sitting high. the lifter came out of an 87 305 caprice so i figured it was the same. Any suggestions?
Old Apr 23, 2010 | 04:13 PM
five7kid's Avatar
I don't suppose that particular cam lobe is up at this time.
Old Apr 23, 2010 | 07:01 PM
russlavoie's Avatar
Re: Any tips?
i actually finished it. It actually came out really good i painted the block and all the brackets the intake manifold all black. Just have to finish the body now and im done.
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 15, 2015 06:37 AM
Night rider327
Sep 25, 2015 04:47 AM
