A/c compressor
Old Apr 20, 2010 | 04:35 PM
valdimar's Avatar
Car: 1989 Camaro RS
Engine: LO3
A/c compressor
I have an '89 Camaro RS w/ 305. I noticed that A/C compressor cycles on for about 3 seconds and then off about the same. Is this normal? Air not really cold either, but works and no leaks. Any comments? Thanks
Old Apr 20, 2010 | 05:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Most likely it's low on refrigerant.
Old Apr 20, 2010 | 05:40 PM
valdimar's Avatar
Car: 1989 Camaro RS
Engine: LO3
Re: A/c compressor
The guy I bought it from recharged it and they put yellow dye in to expose leak. I never saw any leaks, but your probably right. After all, I think the former owners spent a lot to get a/c fixed in the past numerous times. Thanks
Old Apr 20, 2010 | 09:26 PM
afbadger's Avatar
Car: 1989 Trans AM GTA
Engine: 5.7 Stock
Re: A/c compressor
I had the same problem with my 89 GTA, i took it in to check for leaks, all the lines were good but found the compresser itself was cracked all the way around. I kept charging it and it would be good for a day or two then be completly depleted. Sounds like you might have the same problem. luckily compressors arent that expensive. good luck.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
Ironhead38
Sep 7, 2015 02:26 PM
