what are the advantages of........
Old Apr 22, 2010 | 06:45 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
6" connecting rods over 5.7"? Do i have to run a thicker HG? Does it affect compression ratios? Do i have to use longer pushrods? I need some info... thanks in advance.
Old Apr 22, 2010 | 07:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Connecting rod length changes the kinematics of piston movement. The piston velocity will be different as it approaches TDC/BDC, for instance, with 6" vs. 5.7" rods. Also affects side loading of the piston.
You need pistons made for your stroke and rod length. The piston location at TDC will be the same regardless of rod length (well, not different because of one rod length vs. the other - you can get slightly different pin height pistons, but we're talking 0.025" differences, not the 0.300" difference in rod lengths).
Old Apr 22, 2010 | 07:34 PM
Copchaser's Avatar
Re: what are the advantages of........
So is it beneficial to up the stroke that little bit or would it even matter? Also, are I beam rods just lighter than H beams or is there a distinct diff between the two?
Old Apr 23, 2010 | 04:08 PM
five7kid's Avatar
The length of the rod does not affect the stroke or the length of the pushrods. Stroke is completely determined by the crankshaft. Pushrod length is a completely different topic.
H-beams are typically lighter than I-beams.
djmarch
Oct 2, 2015 10:41 PM
age
Aftermarket Product Review
Dec 5, 2001 06:20 PM
RMK
Mar 26, 2001 07:46 PM
mostafa3k
Mar 19, 2001 10:40 PM
496Monte
Jul 24, 2000 10:03 AM
