Do I have to run crush washers with my afrs
Old Apr 25, 2010 | 09:15 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I got the new motor running and Ive been reading that some people say you need crush washers for the spark plugs on any aluminum head. Ive got afr 190's and the plugs in it now do not have them. My signature has all the mods to my motor,, any recommendations for plugs?
Old Apr 25, 2010 | 10:25 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Do I have to run crush washers with my afrs
Yes you should use washers with them, but really any flat washer plug would work. Just make sure the reach is correct.
I am very partial to Autolite plugs. People have different favorites.
As far as the washer crushing or not, well I don't think that matters so much. With the type of plugs I use, they can be reused almost indefinitely and I doubt there is much real crush left after several installs. It is important to use a good high-temp anti-seize on the threads though.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
CRFred
Feb 7, 2016 11:39 PM
355tpipickup
Aug 19, 2015 10:02 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
