replacing fan motor needs tips
Old Apr 30, 2010 | 05:40 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
What is needed to replace the engine fan?
just the motor? how do you remove the fan it self and replace the motor?
is there anything else that needs to be replaced?
fan switch and relays and wiring is fine lets just concentrate on the fan itself.
any tips or steps?
Old Apr 30, 2010 | 08:59 PM
thedrewdotcom's Avatar
Car: 1986 IROC
Re: replacing fan motor needs tips
there are 4 bolts that hold it in, 1 at each corner of the cooling fan bracket.
Old Apr 30, 2010 | 09:00 PM
Bobby_80s's Avatar
Axle/Gears: no idea
thank u i know that part.
but doesnt the fan come off the fan motor somehow? can i just replace the motor without repalcing everything else?
Old Apr 30, 2010 | 09:07 PM
Car: 1986 IROC
yeah you can, there are a few bolts that hold the motor to the fan.
Old Apr 30, 2010 | 09:22 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok i just wanted to make sure thanks so much
Old Apr 30, 2010 | 09:45 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Just remember that the bolt holding the fan blades to the motor is reverse-threaded.
(Left is tight, Right is loose)
Old Apr 30, 2010 | 09:55 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ohhh.... very good to know!!!!! thanks
eightsixseven
Dec 16, 2024 01:50 PM
TheExaminer
Aug 26, 2015 04:59 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Leggman1
Aug 6, 2015 04:15 AM
NBrehm
Aug 5, 2015 07:57 PM
