Small base circle cam questions
Old May 1, 2010 | 02:45 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just purchased a small base cirlce cam for my 383 build and was wondering if the fact that it is a small base circle cam, if it affects the way the camshaft performs. Are there any pros or cons going with a small base circle cam or is it just for clearance reasons?
Old May 1, 2010 | 03:02 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Small base circle cam questions
i doesn't hurt performance. just check rocker arm geometry. the lifters will sit a little lower in the bores.
Frozer!!!
Jan 19, 2024 04:55 PM
junkcltr
Aug 2, 2019 11:12 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
