Runs great in open loop, but bad on closed.
Old May 2, 2010 | 12:24 PM
Crazymidget01's Avatar
I have an 1985 Camaro 2.8L, manual trans. Basically when it is first started, running in open-loop the car runs really well. As soon as it heats up and goes into closed-loop, it bogs and has hardly any pickup. I have changed the following parts so far: throttle position, O2 and MAF sensors, Ignition Coil and module, cap, rotor, EGR Valve. All vacume lines have been fixed of leaks. I checked for codes and got code 32, 42, and 45. Not sure where to start diagnosing this problem. Last time I brought it to the shop, the mechanic mentioned something about high pressure in the gas lines. Any help figuring this problem out would be much apreciated!
Thanks Joe
Old May 3, 2010 | 04:18 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: Runs great in open loop, but bad on closed.
Get a manual and track down the trouble-shooting procedures for those codes. That's the first step.
Jake
Old May 3, 2010 | 04:32 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
What Jake said. If you cant find a good manual, and factory(Helms Publishing) is the only one I can recommend. Your local library will have All Data & Mitchell online. These resources are designed for professional techs with proper equipment and decent knowledge. If diag is beyond your scope you should get some literature on the subject and read up. Amazon has books on everything. Good luck
Old May 3, 2010 | 04:42 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
High fuel pressure points to a faulty fuel pressure regulator or restricted return line. Check fuel pressure with a 100 psi fuel pressure gauge. Should be 35psi at idle, 42psi on throttle snap. Just a place to start. Also, MAF and O2 sensors can be checked by disconntecting them. It forces the ECM into mem-cal so it ignores the disconntected sensor. If the engine runs well with sensor out of system, suspect that sensor. Perform test procedures in manual before replacing parts unless you have known good testers. Throwing parts at a problem is bad mojo.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Bradsaundry
Aug 12, 2015 12:34 AM
