Distributor gear change?
Old May 2, 2010 | 04:10 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just purchased a new cam for my 383 build. It is an XFI roller cam. Is it necessary to change out the factory distributor gear on my older HEI distributor (internal coil) or will it be alright?
Old May 3, 2010 | 04:14 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: Distributor gear change?
It's a good idea since then you'd have two new mating surfaces.
Moly-Lube both gears wiith an old tooth brush and make sure the teeth are lubed deeply.
Jake
Old May 4, 2010 | 06:12 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Would I have to change material of the gear such as going to a bronze gear, or would the stock one be fine?
Old May 4, 2010 | 06:19 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
only if your cam requires a change
Old May 4, 2010 | 06:21 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
How would I know if it requires a change? All that I know is that the distributor is from a engine that didn't originally have a roller cam.
Old May 4, 2010 | 07:50 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If the distributor came off an engine that used a flat tappet cam, you'll need to change it when using it in conjunction with a roller cam. Call Comp cams and see which one they recommend.
Old May 5, 2010 | 12:41 AM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
I dont want to hijack the thread but I just got a new cam as well and it recommends a new carbon poly composite gear. Anybody every try one of these?
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
jbd1969
Aug 17, 2015 07:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
