Drives like a dog?
Old May 4, 2010 | 08:33 PM
makiguy's Avatar
Drives like a dog?
So my v6 91 camaro is finally coming together and after driving it down the road noticed it doesn't handle speeds over 35 mph very well and hills can be tough. Anything lower like 25 mph it runs like a champ with no problems. Seemed to have backfired at least once while driving it. Exhaust also runs very rich and smells like gas basically. Any idea as to what could be causing these issues?
Old May 4, 2010 | 09:26 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Drives like a dog?
First thought is wrong spark timing.
Old May 4, 2010 | 10:56 PM
vampyrico's Avatar
Car: 1985 Chevrolet Camaro
Engine: V8 lb9 i believe..
Axle/Gears: 10 bolt posi
i would check the timing first, when you car is running at low speeds and rpms, the engine can run fine, but as you accelerate the engine will adjust the time, and can do so just enough to make it run like crap.
is your check engine light on?
Old May 5, 2010 | 03:08 PM
makiguy's Avatar
Well I did just set the timing not to long ago and i guess ill check it again just incase it slipped possibly but it only has about 88k miles so I wouldnt imagine the belt could be bad. The check engine light was on for a short time for code 45 which is rich exhaust.
Old May 5, 2010 | 05:14 PM
DeuceNC's Avatar
Mine did this, and it was a clogged cat. Took a sawzall to the exhaust and cut it out, car ran like a champ. Granted, I knew I was redoing the exhaust soon, so cutting it out didn't matter much.
Old May 5, 2010 | 05:51 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Timing...mine ran rich b4 i got it tuned..and i think it was the timing.
Old May 5, 2010 | 06:29 PM
makiguy's Avatar
Still have to check the timing but no its not the cat its brand new.
NORTz89
May 20, 2020 03:51 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
