FUEL PUMP PROBLEMS PLEASE HELP!!
Old May 5, 2010 | 02:29 AM
Murphy-Iroc-87's Avatar
Car: 1987 Chevy Iroc-Z Z28 Camaro
Engine: 357CI L98
Axle/Gears: 2-77 =[
Alright guys. let me just break this whole thing down to you. i just rebuilt my 350 may 2nd. and about 15 mins into my cam break in my fuel pump just quits. well ****. so i pull the whole rear end, exhaust, drop tank replace pump. okay set it back up and it still doesn't work!! i replaced the fuel pump relay. nope nothing. and the wiring harness in the tank that connects the pump to the top of the tank. and nothing. i have no idea what to do now im just really frustrated with everything about it. after rebuilding the motor (from bare block) and tranny. everthing on that end works perfectly. but now this crap happens. and idk what to do so someone please! any help i would appreciate it alot! its an 87 iroc TPI 350.
Thanks, Lee
Old May 5, 2010 | 01:26 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: FUEL PUMP PROBLEMS PLEASE HELP!!
Hi Lee,
I would unplug the relay and see if there is voltage there with the key forward. If not, I think there is a fuse for the fuel pump (but can't remmeber for sure).
Hope this helps.
Old May 5, 2010 | 07:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There's a fuse tucked in the fenderwell behind the battery in a weatherpack - check it.
Old May 6, 2010 | 02:27 PM
Engine: 357CI L98
Axle/Gears: 2-77 =[
Yeah thanks everyone i think i got it. i think it was the wires to the ign mod and it was telling the computer not to turn on the pump kuz there was no spark =[ but i just figured that would last night so we will see once i put back everything i tore apart lol
Old May 6, 2010 | 02:35 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
lesson learned... start with the basics... ...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
