blown head gasket?
Old May 6, 2010 | 01:10 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
blown head gasket?
I did have a lot of blue smoke coming from the tail pipe and I put a 650 Edelbrock on there and it stopped the blue smoke. I now think I have a bad head gasket or crack head or even block. When the engine is cold I open the radiator cap and you can see white foam coming up. The coolant isn't dropping at all just white bubbling, I believe its a head gasket. I also have a really late throttle response too. When I give it come throttle it will take 1-2 secs before there is any rev. Can a blown head gasket make it have a late throttle response like that?
Old May 6, 2010 | 01:19 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
Re: blown head gasket?
does your exhaust smell sweet? is there water in the oil? oil in the radiator? does the car get hot?
Old May 6, 2010 | 01:30 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
exhaust smelled like gas until I put a new carb on. The oil seems a little watered down but no milky looking oil. The car doesn't get hot at all.
3rd gen money
Sep 8, 2015 11:40 PM
earlpote
Aug 28, 2015 10:42 AM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
