car backfires under deceleration from 3000-2400rpm
Old May 7, 2010 | 10:30 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i just replaced the distributor with an msd and the car started to backfire under deceleration with flames shortly after. what would cause this. its probaly a good 10 small-large backfires during each decel. more like pops in the exhaust not really loud like gunshots or anything iots just really annoying people complementing the flames lol. please guys help me
Old May 7, 2010 | 10:33 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: car backfires under deceleration from 3000-2400rpm
also if this may have anything to do with it during the install of the dizzy i have hooker headers with the air tube capped off on the end and 2-3 of the tubes snapped near the header so its leaking there.
Old May 8, 2010 | 11:42 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
What did you set your ignition timing to? This sounds like bad timing..
Old May 8, 2010 | 07:45 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
About 10 degrees
Old May 9, 2010 | 01:41 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
with a leak like you have, under decel it will pull fresh air into the headers and will cause a backfire in the exhaust.
you'll need to get the leaks fixed.
Old May 9, 2010 | 10:10 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
+1
Exhaust leaks up near the engine will cause what you describe.
Old May 10, 2010 | 12:38 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
im gonig to weld them up next chance i have...hope you guys are right.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
