What Size Bolt...
Old May 8, 2010 | 10:16 AM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
What Size Bolt...
What is the length of the bolt that holds the balancer on? The goober before me used a long bolt then built up washers to keep it from bottoming out
my guess is 2.75"
looks like it's a 7/16-20. I assumed metric
Old May 8, 2010 | 10:22 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: What Size Bolt...
The damper bolt is supposed to be a unique, specific item with a specific, thick washer. Best to just order the correct new bolt with washer.
Old May 8, 2010 | 11:17 AM
Car: 1986 Trans Am
Engine: 5.0
Can you be more specific with your answer?
It currently has a grade 8 bolt with the thick washer, but it does look to be metric. The end is buggered, but my thread chaser didn't clean it as I had hoped.
Old May 8, 2010 | 11:43 AM
Car: 1986 Trans Am
Engine: 5.0
Found the proper 7/16 bolt at the store
mr gasket saves the day
•edit• the mr gasket bolt was about 1/2" too short
back to using a new grade 8 bolt.
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
