36# ford injectors?
Old May 8, 2010 | 11:12 AM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
36# ford injectors?
Ok so I bought A HSR from ebay that came with eight 36# injectors all new never installed, so he claimed. well one of the injectors has a small hole in the plastic tip, is this still good or no? Also seven of the eight injectors have the same number (927) stamped on them... its the only number i can make out. The other odd ball reads (060). They all say ford and it looks like they all have been scribed on at the base of the red fitting. Can anyone verify or did I get ripped?36# ford injectors?-img_3749.jpg
Old May 8, 2010 | 11:15 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 36# ford injectors?
you should also post this in the TPI section
Old May 8, 2010 | 02:26 PM
bonesbrakr's Avatar
replace the cap on the injector since they are very cheap and if memory serves me right those are 30lb injectors not 36.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
