Annoying noise - stops with slight pressure to clutch
Subscribe
May 8, 2010 | 06:48 PM
I'm almost done restoring my 85 camaro iroc z28 and I have it on the road and I've ran into a few problems but I've fixed all of them thus far. The issue now is that I hear a squealing noise while my car is running, it is not always there and it seems to go away when I'm going faster.
Pushing the clutch a cm forward, or just a very small distance, just resting your foot there pretty much, stops the sound. Now I'm thinking it is the throwout bearing needing to be greased or something, I just had my transmission out to be rebuilt too...what do you guys think it is? My car sounds great and it takes away from it, it's not toooo loud but it pisses me off.
Reply 0
May 8, 2010 | 07:08 PM
Re: Annoying noise - stops with slight pressure to clutch
It definitely sounds like your throwout bearing. The only way to fix it is to replace it (they are pretty cheap).
Reply 0
May 8, 2010 | 07:09 PM
It probably is the throwout bearing..alright, thanks man, I guess ill be replacing a throwout bearing lol.
Reply 0
May 16, 2010 | 11:03 PM
mine makes the same noice occasionally i just tap the cltch pedal a few times and it goes away.
Reply 0
Subscribe
