Help stalls and misses under throttle
Old May 10, 2010 | 05:57 PM
Corey.g's Avatar
Hey guys this is driving me crazy i have checked everything and i still have
a miss bad under throttle?305 tpi at 1/4 throttle the miss is realy bad at 1/2 throttle it runs better but still a miss ? Help please
Old May 10, 2010 | 06:15 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Help stalls and misses under throttle
if all looks good test the injectors. you can ohm them or fire them with special tools with the engine off and check fuel pressure drop. btw what is your fuel pressure? spec is 38-48psi.
Old May 10, 2010 | 06:53 PM
Corey.g's Avatar
After market fuel pump about 45 when i checked
92camaroJoe
Jul 29, 2023 07:57 PM
777Shock777
Oct 29, 2015 04:30 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
