pics of altenator and help with installing
Old May 12, 2010 | 12:22 AM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
so i took out the altenator to get tested and came back good and now i tested the battery and it was low so i need to reinstall the altenator but honestly now i cant figure out how to reinstall it iv got all the wires connected but cant get it mounted so i need some instructions/tips on how to do that and need some pictures on what they look like installed Thanks.
Old May 12, 2010 | 01:20 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: pics of altenator and help with installing
Can we assume that you have a serpentine belt system?
The alternator was mounted on the upper right, correct?
Old May 12, 2010 | 01:23 PM
Twin_Turbo's Avatar
He has an 87 w/ a serp belt on the alt and V belts on everything else.
The alternator actually installs "upside down" in these, there's no real up and down but if you look at the case, the part with the large fin will be on the bottom and the cooling exhaust ports are on the top.
Old May 13, 2010 | 12:43 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello iroc stangs!!
If you have all the wires hooked up, the same way that they came off the alternator, it should be really easy to figure out how to install it, especially since you took it out????
What exactly is the problem that your having, is it not mounting up to the holes properly, can't get the bolts to go through??? Etc....what exactly???
Old May 13, 2010 | 10:07 PM
Engine: 305TPI
Originally Posted by 87IROC-DAN61
Hello iroc stangs!!
i know it should be easy but i litterly forget everything lol. i just cant rember how i took it out and its harder now since you have to hold it while bolting it on. thats why i need pics so i can see exactly how it needs to bolt on.
Old May 13, 2010 | 11:12 PM
Engine: 305TPI
ok so i got pretty much all the bolts on but there i still the negative battery wire so does this connect with the other wires behind the alt or somewhere else! help!
Old May 13, 2010 | 11:21 PM
Hello iroc stangs!!
Twin_Turbo's pictures should help you then, there is a bracket that mounts behind the alternator's bottom bolt, that can be a bit of a "PITA"!!
I spent twenty minutes cursing out the bottom bolt, when all it really was, was the bracket for the AIR pump diverter valve in the way, that needed some loosening, so that everything would fit!!
let me know if you get stuck!!
P.S. Post a picture if you can!!!
Old May 13, 2010 | 11:31 PM
Engine: 305TPI
Hello iroc stangs!!
you talking about the big long bolt? ya tell me about it if removed that bolt after having it all the way in 3 times now because of diffrent reasons lol. also its dark out so im using a 750watt worklight RIGHT next to me and trust me it puts out ALOT of heat and its still fairly warm out here lol. ok i still dont know where to put the negative cable to the altenator it doesnt go where the other wires goes to so where does it go! i cant see it in twin turbos pics since it a fairly thin metal piece about the size of a nickel. btw i would put up pics of the prob but im actually using my laptob out side and dont feel like draggin the camera and usb cable out here and dealing with that right now lol.
Old May 14, 2010 | 12:00 AM
Hello iroc stangs!!
The negative battery cable bolts to the bracket, right below the hole for the bottom bolt!!
P.S. Look at Twin_Turbo's first picture, you can see the bracket with the bottom bolt installed, the negative battery cable goes right there below it, in the next hole down!!
Old May 14, 2010 | 12:34 AM
Engine: 305TPI
Hello iroc stangs!!
hi, thanks i didnt even think about the second smaller hole on the bracket i was trying the top one lol. also i cant get the belt back on what bolt do i have to twist for lossin/tighten the belt? thanks for all your help
Old May 14, 2010 | 12:50 AM
Hello iroc stangs!!
The alternator only has two bolts, one at the top, and one at the bottom, the top one runs through a bracket with a long slot in it, this is the adjustment bolt, the bottom bolt is just a pivot bolt, both need to be loose in order to tighten up the alternator belt!!
The belt can be a bit of a bear if you have replaced it with another one that is slightly smaller, too long of a belt, and you will run into a problem with not being able to get it tight enough!!
Basically, to tighten up the alternator belt, you have both bolts loose, but not falling out loose, just enough to let the alternator slide, applying some force to the alternator is the tricky part, once you have the proper tension on the belt, tighten up the top bolt first, then the bottom, be careful with the top bolt, that you don't break the "ear" off of the alternator!!
Make sure that you recheck your belt tension after you tighten up the bolts!!!
Old May 14, 2010 | 12:53 AM
Engine: 305TPI
Hello iroc stangs!!
well i currently dont have any bolts on the alt right now other then the long bolt and for the wires and neg batt. i just cant get the belt on
Old May 14, 2010 | 12:55 AM
Hello iroc stangs!!
Is it the same belt that you took off??
Old May 14, 2010 | 01:01 AM
Engine: 305TPI
Hello iroc stangs!!
now im confused? the only belt iv tooken off was the belt that goes over the alt. also for tightening the belt do i need the bolt that is on the braket right above where you connect the neg battery cable?
Old May 14, 2010 | 01:19 AM
Hello iroc stangs!!
Working from the bottom bracket up, you should have three holes in the bottom bracket, the bottom most one is for the air pump adjustment bolt, the next one up is for the neg battery cable attachment, and the next one is for the alternator's bottom pivot bolt!! The only other bolt is the one at the top of the alternator that goes through the top bracket and screws into the alternator!!
If you can't get the belt on the alternator, are you able to pivot it towards the water pump, this will give you some more belt slack, check that the wires aren't holding you back!!
Old May 14, 2010 | 01:35 AM
Engine: 305TPI
Hello iroc stangs!!
ok well honestly i dont even know what the water pump looks like lol! like i can get the belt to go on the alt. and then the bigger bottom pulley barely but forget about it on the inbetween smaller pulley. also i might if i can, call it a night and try to push her back in the garage but the car wont get out of park because the brake is stiff so is there anything i can do to get the brake pedal back to normal? thanks.
Old May 14, 2010 | 01:50 AM
Hello iroc stangs!!
Okay, can you post a picture tomorrow with your results so far, that way I'll have a better understanding of what your dealing with, as it should be a real easy fix!!
As for the brake pedal problem, make sure that you have nothing in the way of any moving parts under the hood, repeat make sure!! Once you are sure about that, turn over the engine with the starter a couple of times, and you should be able to pull the transmission out of park!!
Be careful with that alternator belt, don't let it get caught on anything!!
Old May 14, 2010 | 02:05 AM
The brake pedal is stiff because you've used up the vacuum reserve for the power brakes, only way to get it back to "normal" is to run the motor (bad idea right now lol)
I second the notion of taking a pic or 2 for us, that will help us a lot.
As for what your water pump looks like, viewing the front of the motor, right in the middle, you will see something that resembles a giant blob of rust, with hoses coming out of it, one of which goes to the bottom hose on your radiator. This is your water pump the pump will have a pulley on the front of it
Old May 14, 2010 | 02:27 AM
Engine: 305TPI
thanks guys i'll defintly get pictures tomorrow and hope to get this fixed! i hate not being able to pull her out and clean her up like i always do and you should see my garage its a MESS lol. thanks again
Old May 15, 2010 | 03:59 PM
Engine: 305TPI
Update: i had a few car guys help me install the altenator so all that is in including battery which I charged as much as my charger lets me but still the car wont do squat? when i turn the key there is nothing no cranking or anything unlike before when it would crank for a split second and die.
so is this probaly the starter then? im soooo close to getting the starter out but my problem i cant figure out how to get the bolt out of the bracket that holds it in because there isnt enough room to slide the bolt out??? HELP!
Old May 15, 2010 | 05:32 PM
It sounds like the battery is the real problem
Old May 15, 2010 | 05:47 PM
Engine: 305TPI
i hope so just curious, Why do you think its the battery?
Old May 15, 2010 | 05:59 PM
The way the starter is having "difficulty" cranking, and now it's not cranking at all indicates it has a low charge, and it's being drained.
Also, charging it as much as the battery charger will allow doesn't necessarily mean much. Older batteries simply don't hold a charge as well, and your portable charger isn't the best thing to charge it with.
Have you tried jump starting the car? That'll give you a better idea of if it's the battery or starter
Vintageracer
Jan 10, 2020 05:33 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
aaron7
Aug 17, 2016 06:02 PM
mustangman65_79
Aug 13, 2015 07:36 AM
sonu1975
Aug 11, 2015 08:38 AM
