Camaro problems
Old May 15, 2010 | 11:24 AM
specialtard's Avatar
Camaro problems
Hey guys, this is my first thread. However I lurk often.
Here is my problem, see if I can get some help.
I have a 1985 Camaro 2.8 fuel injected. When I start the engine it goes for about 2 seconds and then dies. I have gotten it to idle if I take my air filter off, but as soon as you even touch the gas it just bogs down.
So far I have replaced the in-line fuel filter, the spark plugs, and the cap and rotor. I want to get this fixed once and for all!
Old May 15, 2010 | 11:30 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Camaro problems
Is the SES light working? Does it flash or stay on? Have you checked the IAC and the TPS?
Old May 15, 2010 | 11:42 AM
Re: Camaro problems
I was just looking into replacing the TPS, how would I go about testing this stuff?
Edit: My check engine light is on and it stays on but that was on before this started. the SES (servie engine soon?) light is not on
Edit2: Sorry im failry new to automotive repairs. But i learn fast
Old May 15, 2010 | 12:35 PM
Re: Camaro problems
Ok so I just flashed my error codes and I have only one.
54. Low voltage at fuel pump OR Low voltage at Fuel pump relay OR Output failure at quad driver module
Does this mean my fuel pump needs replacing, or could it just be a fuse?
Old May 15, 2010 | 12:40 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Camaro problems
I'd start by fixing the cause of code 54. I can't tell you how off the top of my head, that's what Chiltons manuals and this forum are for. I specialize in internal engine.
the SES light and Check Engine light are just 2 different names for the same thing.
Sorry that's the most I can help without doing your research for you.
92camaroJoe
Jul 29, 2023 07:57 PM
TheJoeY88
Dec 31, 2016 07:30 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
