EGR valve specifics
Car: 1992 Camaro
Engine: LB9
Transmission: WC T5
Axle/Gears: 10 Bolt - 3.42
EGR valve specifics
Hey guys, I have a problem with my '92 b4c that i'm trying to hunt down. It has an idle problem and the exhaust sputters. The idle will stay high at around 1300 rpm and won't drop unless I restart the car. The problem is slowly getting better or at least it's not doing it as often but i'd like to fix it so I can see what my true mileage is. I've changed the temp sensor, IAC valve and have done a major tuneup. I understand the basic operation of the egr valve and I know it can cause a surging idle but how about a high idle if stuck open or closed. The car also runs hot on the highway and not in traffic, usually around 240. The fans turn on at 222 and off at 215 degrees. If too much burned gas is getting into the cylinder would that raise engine temp? The tps seems to be working fine although i've seen voltages of .63 to .87 at idle.
The only thing I can think of if maybe a bad MAP, EGR or ECM or maybe a leaky throttle body,(it's a TPI 305 engine).
Any ideas?
Any ideas?
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: EGR valve specifics
you could always remove and block off the egr. its one of the first things i did to my motor. your ses light willl be on all the time if you do.
Transmission: 4L80E/4L80E
Hotrodboba400
Dec 10, 2019 07:07 PM
