Vacuum for modulator valve?
Old May 20, 2010 | 06:16 PM
lowridetractor's Avatar
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
can i drill a vacuum port for my modulator valve here where the green dot is?
Old May 20, 2010 | 06:20 PM
Twin_Turbo's Avatar
Re: Vacuum for modulator valve?
no port left on the carb?
Old May 20, 2010 | 06:24 PM
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
i have on on the back for the brake booster, the one on the front center for the pvc, and the one on the front to the right for vaccum advanced. can i use the last one for the mod. valve? btw its a eldlebrock 750
Old May 20, 2010 | 08:04 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Need to check what type port it is .
Most carbs have a "ported " vac port which does not see vac full time and one that has constant intake vac .You want the modulator to have full time vac.
Failing that you could '"T " into the dist vac line to save having to drill a new hole in intake
NB
Most aftermarket intake have a threaded port on the intake for brake hookup so you dont have to use a carb port
Old May 20, 2010 | 09:31 PM
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
yes i thought that to about most aftermarket intakes. but after i put this one on i realized it didn't have one. and fyi this is a HI-TECH Torque-Link intake.
Vette- so what you are saying is that i can put a T in my vacuum advance and it will still work?. I think the other vacuum port is "ported". I will recheck when it comes time to start-up.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
middian
Sep 5, 2015 01:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
