power valves
power valves
355 with P1sc procharger and Holley 750 carb. Engine runs great, AFR looks good, WOT is unreal. Im not running Power valves in the carb for now. I did in the past and the cruise was much better, It runs a little on the rich side now at cruise with a slight burble sound from the exhaust. I have been told by some to not runs power valves in a blow through carb that they would not work under boost, I dont see how this could be true, I have asked alot of people but I cant get anyone to explain how PV,s work under boost pressure. I would like to install the pv,s back in the carb. All the other mods have been done to the carburetor and the fuel system, fuel cell, twin pumps, #10 AN line, fuel pressure and volume is not a problem.
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
ambainb
Apr 25, 2016 09:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
