Gas fume canister?
Old May 22, 2010 | 11:55 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Gas fume canister?
do you need that stupid looking gas fume collector?
does it prevent vapor lock?
i removed my q-jet so i dont have a vacuum line running between the two anymore. so i removed it and ran a vacumm line from the tank connection to outside the fender.
Old May 23, 2010 | 06:19 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: Gas fume canister?
you dont need it but it does keep your car from reaking of gas. All it does is collect the vapors from the gas tank and when you start the car it is purged by the engine vacuum. Also be sure to put a check valve on the line to keep dirt and grime from getting in.
Old May 25, 2010 | 06:13 PM
TNT_Z28's Avatar
thanx, it already has a check valve that i left intact. i ran a line underneath the fender so hopefully the fumes get sucked out there
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86maro_252
Oct 10, 2015 06:52 PM
reactor60
Sep 22, 2015 01:44 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
