horrible engine knock
Old May 24, 2010 | 05:16 AM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
Just swapped in a used l98
This motor is not looking so good. It was running fine untill after I changed the oil and took it for a full throttle run and it started knocking bad. It sounds like valvetrain knock but I checked all the lifters and none were loose. It has so much sludge in the heads the oil wouldnt even drain back out of the pass side one!! If a lifted was wad wouldnt I be able to tighten that rocker up ad make the knock go away??
Its not a consistan knock... its like knock...knock knock knock knock......knock knock.....knock knock knock...... lol
Just thought I might ask... oil pressure is good and it doesnt sound like a rod at all but I could be wrong
Old May 24, 2010 | 05:53 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: horrible engine knock
Might be good to run a can of SeaFoam through it and see if you can get some of the sludge/carbon build up cleaned out. You can buy that from most Auto Part Stores. That stuff will make the motor run a little hot and smoke, but it'll burn out all the carbon buildup. I usually add 1/3 can to gas, 1/3 can slowly down brake booster vacuum line with the motor running (may have to rev it a little to keep it running), and a 1/3 can to oil (run it for a few minutes to get it nice and warm then change the oil). Stuff worked great on my mother-in-law's V6 Bonneville after she didn't change the oil for 2 years.
Old May 24, 2010 | 02:57 PM
wannafbody's Avatar
Car: 88 GTA
im kinda scared to run it but I guess I got nothing to loose now. It sounds like someone is banging a hammer on the intake
Old May 24, 2010 | 03:27 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
I hate to tell you this but with that much carbon in there your engine is toast carbon in a engine is from not changing the oil and over heating and that smokes your bearings and the carbon plugs up everything.
Old May 24, 2010 | 04:43 PM
Engine: 383 SBC
Well if it's smacking around that loud and hard sounds like it has some major issues...
Old May 24, 2010 | 04:51 PM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
Sludge and carbon is totally diffrent, sludge is from not changing oil, carbon is what sets up on the vavles and is fuel related.....but yes the motor with lots of sludge is not good........
Old May 24, 2010 | 07:49 PM
wannafbody's Avatar
Car: 88 GTA
well im never buying a used engine again....
I heard it run so I just jumped on it, it was $300 and I should have atleast pulled the valve covers.
My L98 that spun a rod bering looks brand new in the oil pan and under the valvecovers.
This junk I swapped in looks like it has 500,000 miles on it and never had an oil change...
I guess ill just go hold the pedal down till something pops!!!!!!!!!!!
Old May 25, 2010 | 04:33 AM
Car: 92 camaro B4C
Transmission: t5
diffrent
vavles
I believe wear talking about the crankcase not the combustion chamber.
And yes your right carbon does form on valves and pistons in the combustion chamber and can cause a spark knock but that's not the kind of knock wear talking about
Polo Z03
Sep 10, 2015 06:43 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
