alt not charging battery but alt in testing good
Old May 24, 2010 | 11:43 AM
IfknROC85's Avatar
Car: 85 iroc z28
Engine: 305 tpi
any help would be nice....my altinator is testing good from my local auto store but i cant figure out why my alt is not putting any power to my battery is my wiring wrong or or something else please help
Old May 24, 2010 | 01:57 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: alt not charging battery but alt in testing good
The power wire from the alternator usually goes down to the large positive post on the starter where the battery cable connects.
Old May 24, 2010 | 10:44 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Have your battery tested, it may just not be able to hold a charge. If that checks out then its got to be a wire issue.
Old May 24, 2010 | 11:00 PM
IfknROC85's Avatar
Car: 85 iroc z28
Engine: 305 tpi
the battery is a week old but we just noticed it wasent getting a charge back to it yesterday....haha when the car lost juice on a test run.....so we could of smoked the battery so that might be an issue...im going to check the starter......my volts gauge shows it at 13v when i start it and slowly drains down to under ten
Old May 25, 2010 | 11:04 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
the power for the factory voltmeter comes from a fuseable link that also goes down to the positive post on the starter.
Likely problems are loose connections at the starter, and/or a bad cable between the alternator and starter, and/or a bad large cable between the battery and the starter.
There is a possible chance that you have a bad or damaged battery, but that chance is pretty low.
BRoss99
Aug 10, 2025 05:08 PM
Derick15
Sep 17, 2016 05:28 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
