Please help with rookie questions.
Old May 24, 2010 | 03:24 PM
syellow's Avatar
I was on another camaro board and only got one response. Hopefully it's more helpful here. I just purchase an 88 camaro with a 305 TBI. The TBI unit was rebuilt. I went to go through an emissions check today and they didn't even test it because it was smoking. Not sure the color of the smoke because I didn't see it. I ordered a new head gasket set along with the valve stem seals. Do you guys think this will fix it, or do you think it might be the piston rings. I can do a compression check, what is the compression supposed to be at? Any other suggestions? Thanks!
Old May 24, 2010 | 03:34 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
Re: Please help with rookie questions.
You need to do a wet and dry compression test dry to check for the valve and wet with oil to check for bad rings.
Old May 24, 2010 | 03:48 PM
syellow's Avatar
What is the difference between a wet and dry? I've always just plugged up the tester and did the check... Which method is this? Sorry for the dumb question, but I have to learn somewhere.
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
TheExaminer
Sep 6, 2015 11:40 PM
