Another l98 build wishlist
Old May 26, 2010 | 10:51 AM
street_carnage's Avatar
Car: 89 GTA
Engine: 5.7L
Just got an inheritance, looking to spend it wisely
what do you guys think, most of it is in order how i want to do it. looking for street/strip trying to get into low 12's. What do you think the priority mods should be. obviously doing bolt-ons first. Trying to get most bang for buck right now, just want to make it more aggressive for street. dont want to do any BIG jobs until it is stored for next winter. how much hp/torque do you think i will gain? advice on heads/cam?
Current: 89 GTA L98, auto, custom CAI, A.I.R. Delete, Cat delete, 3” magnaflow catback, Edelbrock adj. Panhard bar
Suspension/Chassis:
Firestone firehawk Indy 500 oval track tires 255/50/R16
KYB gas-a-just rear shocks, GR2 front struts
Poly Trans. mount
Replace worn bushings
BMR Subframe connectors
BMR Wonderbar
Spohn LCA relocation brackets
Spohn Tubular lower control arms
Eibach Sportlines or Dropzone springs
Adjustable torque arm
torque arm crossmember mount
Engine/Drivetrain:
adjust TPS voltage, set IAC
Hooker 2055 headers/Y-pipe, no AIR tubes
Descreen MAF
TPIS airfoil
TPIS adj. Fuel pressure regulator set between 47-50 psi
bigger injectors
3.73 gears
march underdrive pulleys
Iridium spark plugs
8 mm or larger wires
accell/msd cap/rotor
MSD Electronic ignition coil
MSD Ignition amplifier with harness adapter
TPIS,Edelbrock, or SLP Runners
TPIS Big mouth intake
BBK 52mm or 58mm throttle body
? Heads
? roller Cam
Timing Chain
roller Rockers
Thinner head gaskets for more compression
50-150hp nitrous shot
PcmForLess Tune
2400-3200 stall
Shift kit
Brakes:
1LE or LS1 brake upgrade
Exterior:
Tint windows
hood ?
touch up paint chips
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
Tarizza
Sep 24, 2015 12:57 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Winchester1094
Sep 15, 2015 09:48 AM
