fuel pressure
Old May 26, 2010 | 12:50 PM
matt1970pon's Avatar
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Axle/Gears: 3.45 g92
fuel pressure
I just check my fuel pressure on a 305 TPI motor. at start up it pegged the needle at 45lb plus. I thought TPI cars ran around 30-35psi.Am I right? If so my fuel reg. needs to be replaced. I have a rough idle and a fuelly smell exhaust.Can some confirm this?Thanks
Old May 26, 2010 | 10:36 PM
ty001's Avatar
Car: 91 Camaro
Engine: 3.1
Re: fuel pressure
100% stock tbi engines enjoy 13-13.5psi and those with some modifications enjoy 14-14.25psi.
Old May 27, 2010 | 06:49 AM
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Re: fuel pressure
ok but its a tuned port motor..TPI..I was told anything over 47psi reg. is bad.That is a constant pressure. Apon start up it could hit that then drop to mid 30's.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
