Painting an engine
Old May 29, 2010 | 08:40 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Painting an engine
Not sure if this belongs here or in another area but figured I'd post it here.
I am painting my engine comparment. I am using regular base coat/ clear coat paint. My question is, can I use this on my engine block and intake manifold, or do they get too hot? Would using high temp primer make any difference?
Old May 30, 2010 | 11:08 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Painting an engine
I wondered this myself, and recently tried it on my thermostat housing/neck to see if it handles the heat. So far, so good. I used a high heat paint and sprayed Nason clearcoat over it. 700+ miles later and it hasn't peeled off from the heat. I suspect basecoat with clear on top would handle the heat fine, but I don't feel like pulling the engine again just to repaint everything with base/clear.
Edit: I would use a high heat primer and go ahead and spray it with base/clear. The part I sprayed clear over has seen temps over 220* and been fine.
Old May 31, 2010 | 01:53 AM
built91Z28's Avatar
Cool. Thats good to hear. I decided that I am going to try it regardless. I got the paint for free. I just need to buy primer and clear. The paint is a Ford color. Bright atlantic blue. Its a little lighter than I wanted, but should look nice. If I dont like it, then atleast all the body work will be completed so painting over it later on shouldnt be too hard.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
