HELP! Ticking Sound from a rebuilt 350 carb.
Old May 29, 2010 | 09:41 PM
defaria27's Avatar
Car: 1992 Camaro Z28
Axle/Gears: factory 373
I have a 78 350 carb engine that has had the bottom end rebuilt with stock heads 1.94/1.50 (which I plan on upgrading soon). I recorded a video on youtube and I can't figure out this ticking noise that seems like it is coming from the 5th or 7th cylinder. Also I have noticed that my timing mark is on the left side instead of the right (This has no ECU, or Emissions). Please help me out, I used 0w-30 oil when I rebuilt the engine, I just changed it to 10w30. I noticed new radiator fluid is yellowish instead of lime green, appears to have oil in it. I took off the valve cover and I noticed there was some green spots in there. White smoke when the exhust starts up. I have a bigger cam, which the machine shop approximated to be 460/484 LFT-MED STREET
http://www.youtube.com/watch?v=DMIUIMwJ7bM
Any input would be greatly appreciated
Old May 29, 2010 | 10:04 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: HELP! Ticking Sound from a rebuilt 350 carb.
It's said that you could usually take a boom or a screw driver and put it to the engine and listen. I looked at your video but can't really hear it. Is it a constant tick? Or does it come and go? Have you checked all your rocker arms?
Old May 30, 2010 | 01:49 PM
defaria27's Avatar
its a high pitched ticking...listen again...sounds using screws as drumsticks on the valve covers. lol . When i changed the 0-w30 oil after inital start. i took valve cover off, checked but not lose...i also dont know what to look for on the arms.
theshackle
Sep 17, 2020 08:26 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
crazynights
Aug 21, 2015 06:53 AM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:55 PM
