Will Not Start
Will Not Start
I have a 1991 Z28 with 1987 L98 motor in it. It will not start, it wont even turn over, even the lights wont go on, I mean noting. Battery is brand new and has a full charge. I don't understand if it has something to do with the VATS System, I don't even know if the car has that. Can Some give more details on this. Also could it be the solenoid/starter But the lights would still go on so anyone have any ideas
thanks for you help
thanks for you help
Car: '85 Camaro z28... '90 300zxTT Z32
Engine: soon to be 350(carb)... VG30DETT
Re: Will Not Start
check the wires before you check anything else
I had a loose wire on my Z32 TT and it had all the same symptoms I had to jiggle it to get power and what not for a while... if you're lucky that's the only problem
92camaroJoe
Aug 13, 2015 06:07 AM
