ENGINE BLOCK CLEANING???
Old Jun 1, 2010 | 08:43 PM
87firebird305V8's Avatar
Car: 87 firebird
Engine: carbed 305
ok, i blew my little 305. and with only 80,000 miles on it i decided to rebuild it. im going to have the engine dipped to clean the sludge and all that stuff. but i was told that it would have little effect on the suface rust it has from being 23 years old. my ? is how do i clean that rust off.
Old Jun 2, 2010 | 01:57 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: ENGINE BLOCK CLEANING???
Acid dipping will clean everything but the good metal off, surface rust included.
Old Jun 2, 2010 | 02:09 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Where Im at tehy wont even dip them anymore. They just bake em.
Old Jun 2, 2010 | 08:06 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Of the shops I've worked at, they've done them each way already mentioned, and in spray cabinets. Baking is the best for the environment. Most shops that do bake, also follow up with a mild form of shot peening. This does pretty well at removing the rust, but requires that every machined surface be re-machined.
This is done even in states that don't require it, so check around. Your alternative is to have it dipped, then before machining, attack it yourself with wire brushes or naval jelly or both.
There is one more alternative: don't worry about it. It'll go another 20 years without being a problem, and the way our engine bays are, noone will ever see it.
Old Jun 4, 2010 | 11:07 PM
Car: 87 firebird
Engine: carbed 305
yeah good point, im rebuilding it with help from my cuz. hes a racer and is using alot of parts and services from racing shops. Ive only called one place about it, i need the money first. i would like to clean it up and paint it red or orange because im gutting everything that i dont need like A/C emissions stuff etc. and then put chrome valve covers on with a chrome air intake with a simple holley double pumper carb. what do they do baking it? just get it really hot or what and whats the most effective or expencive
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
