Distributor arm removal
Old Jun 3, 2010 | 03:02 AM
saga31's Avatar
Car: Camaro RS
Engine: 5000cc TBI
Transmission: manual
Hi all,
First off... greetings from the UK!
I've been having some problems getting my car started so thought I would check the distributor for corrosion. I removed the dustributor cap fine and cleaned the contacts. However, I couldn't remove the distributor arm. They usually just pull off don't they? I didn;t want to force it without checking first as I may be missing a screw or something.
My car is an 89 RS with the 5l TBI engine.
Any help would be much appreciated!
Mark
Old Jun 3, 2010 | 06:20 AM
Damon's Avatar
Re: Distributor arm removal
You mean the rotor? Yes, they just pull off. But the originals are often stuck on the top of the distributor shaft bad enough that removal is a destructive process. Once you finally get it off clean the top of the shaft and smear a little grease on it so that you don't have the same problem in the future.
Old Jun 3, 2010 | 07:21 AM
saga31's Avatar
Car: Camaro RS
Engine: 5000cc TBI
Yes I meant the rotor.
Great... thanks very much.
I can now put a bit more force into getting it off!
Mark
Frozer!!!
Jan 19, 2024 04:55 PM
fbirdroller
Sep 2, 2015 10:27 PM
g.l.mos
Aug 22, 2015 12:02 AM
midias
Aug 15, 2015 05:07 PM
3rdgenparts
Aug 8, 2015 07:09 PM
