possible fuel pump going bad?
Old Jun 5, 2010 | 06:58 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
My new 385 has been surging at idle lately, I checked the fuel psi with a gauge(not running, I have a header off right now) and its jumping erratically 2-3 psi it also drops pressure almost immediately to 0. Does this sound like a fuel pump or a bad pressure regulator. I am currently running an inline booster pump and I do have an adjustable pressure regulator.
Old Jun 5, 2010 | 07:50 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Re: possible fuel pump going bad?
On another note I pulled 30in of vacuum on my afpr and it held at 30 with no drop
Old Jun 5, 2010 | 07:59 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Engine: 355 cu. in. Vortec / TPI / MAF
Axle/Gears: 3.73 Limited Slip
What about the fuel filter it will also cause surging if it has not been replaced in awhile an could possiblely burn out your pump eventually
Old Jun 5, 2010 | 10:58 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
fuel filter has @ 200 miles and less than 3months on it. Just checked the vacuum line to the afpr and it does smell like gas. Even though it holds vacuum and does adjust the fuel pressure properly this means its definetly bad..right?
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Newguy91rs
Aug 7, 2015 09:51 PM
