454 piston slap...thinking about a one hole repair.
Old Jun 6, 2010 | 11:59 PM
87 Burb's Avatar
Picked up another 87 Suburban, This one has a TBI 454. Bought it for parts. Got it really cheap.
The engine runs suprisingly well. Drove it home, but...it's got what I and the previous owner believe is a case of piston slap in one cylinder (reason for the great deal). He unplugs a certain spark plug and the knock under load disappears. Going to check a few more things before I tear into it. He dropped the pan and doesn't believe it's a rod or a main. It hasn't gotten worse after driving it a fair amount.
If it is piston slap due to a collapsed skirt and the bore is not excessively scuffed, how feasible is it to drop the pan, pull a head, maybe hone it with drill to break up the glaze, clean out the debris, replace the bad piston and rings, and run it for a while without incurring the expense of a rebuild?
Where can I find an identical factory 454 piston (new or used)? Where can I get the part number? What type of rings would you recommend?
Anybody done this? How did it work out? General opinions?
Old Jun 7, 2010 | 07:16 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 454 piston slap...thinking about a one hole repair.
I did a GenV 454 engine like that at work years ago. It was a low rpm truck engine. It had a seized wrist pin. Simply changed the piston and the customer was happy. Not a proper repair job but it worked. Picked up a piston and rings from the local GM dealer.
Old Jun 7, 2010 | 02:30 PM
87 Burb's Avatar
Called my local dealer about a piston, wanted $210 for one.
Old Jun 8, 2010 | 10:47 AM
87 Burb's Avatar
Found a used piston and rod from a Gen 5 for $40. My 454 is a Mark 4. Piston looks the same but different part numbers. Silvolite says they are both 5cc, but not sure if the weights are the same.
Anybody else done this or have opinions? Ring recommendations? Other tips?
Old Jun 8, 2010 | 11:36 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Originally Posted by 87 Burb
Other tips?
Get a scale and weight them. If they're within a few percent of each other you're good to go.
Pac J
May 17, 2020 10:44 AM
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
drumstixer
Sep 29, 2015 03:02 PM
Dragonsys
Sep 25, 2015 03:51 PM
