Won't take the gas?? Fuel issue...
Old Jun 2, 2010 | 09:20 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Transmission: built 700R4
Axle/Gears: 3.73 posi
5.7L TPI '90 Iroc, fresh rebuild (3000miles), new fuel pump, & filter. On occation, after running great and getting warmed completely, when you shut it off and re-start the car, it acts as if it's not getting fuel. Fuel pressure is confirmed at 43lbs at the fuel rail, good spark via plug wire #1-header. What gives? It will idle sometimes and just die, or if you touch the gas at all, it acts like it's starving for fuel and dies. Am at a loss and almost wits end with it.
Old Jun 3, 2010 | 03:17 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Fuel Not Kool
Make sure the temperature sensors read correctly.
Scan for codes.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Old Jun 3, 2010 | 09:07 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Re: No Fuel Not Kool
Water temp sensor and oil pressure sending unit replaced already. Ohm'd injectors and checked TPS voltage through it's travel. 47lbs of fuel pressure that doesn't drop off quickly with key off.
I am beginning to think the ECM is toast....Thoughts?
Old Jun 4, 2010 | 08:16 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Tried a new ECM tonight to no avail. I also tried to pull codes and all I'm getting is the normal "12" code repeatedly. Am rapidly running out of ideas on what to do.
Old Jun 5, 2010 | 01:05 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Won't take the gas?? Fuel issue...
CTS that sends engine temp to computer is seperate sensor to those two for the gauges .Is located at front of intake under TB
you shut it off and re-start the car, it acts as if it's not getting fuel.. What gives? .
Have you pulled a spark plug to see whether they are wet or dry ?
Does pressure hold with key off?
Ohm'd injectors
Did you check injector resistance when hot as in when problem occurs?
Old Jun 5, 2010 | 01:20 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/post...381-post6.html
https://www.thirdgen.org/forums/post...996-post2.html
https://www.thirdgen.org/forums/tech...-when-hot.html
Old Jun 5, 2010 | 03:40 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
I removed plug#1 and it did have slight carbon buildup, but not excessive. It did smell of gas, but wasn't wet. Then I took my coolant temp sensor off and it OHM'd 0.0. I heated it with a lighter to see if the resistance changed. It did not. OK, I went to the the parts store and it read much differently than a new one, so I installed a new one. No difference. Still looking for the culprit/problem.
Old Jun 5, 2010 | 05:20 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Removed ignition module, cleaned, and regreased. The car will start and run fairly smooth as long as I squirt a bit of gas into the air intake ports..... I am sure I still have a fuel injection issue. Have a code 42 now after re-installing and starting. Ignition module?
Old Jun 5, 2010 | 05:26 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
If the ignition module were bad, I think it would not run or would be idle much rougher when it's running off of the added gasoline. Maybe the code set when I unplugged it?
Old Jun 5, 2010 | 05:32 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
To answer earlier question...The fuel pressure does hold with the key off. It takes quite a bit to see any drop at all.
I can get it to start, but I can't get the car to run long enough now to heat anything at all......but the headers. Ouch.
Old Jun 5, 2010 | 06:22 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Got it running with a squirt of fuel into the intakes ports. It ran for about 10 minutes at a weak idle and shut off. If I touch the throttle, it dies. I diconnected the batt and the code is cleared.
Am now at a loss again. It runs entirely TOO smooth to be injectors or a spark issue. FP is still 47lbs with key on and holds there. SOMETHING is not telling the injectors to fuel enough DAMMIT.
Old Jun 5, 2010 | 06:47 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Now a code 44 after it idled, somewhat weakly, for 10-15 minutes. Oxygen sensor SHOULD read lean if it barely has enough fuel to run at all.
Old Jun 6, 2010 | 07:52 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Disconnected battery today and put a new ignition control module in it today. Still same results. Cranks and dies immediatly. It will run if I continue to squirt gas slowly into the plenum. Am now at a loss. Don't really know where to go from here now.
Old Jun 6, 2010 | 08:11 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
IF I had am injector shorted out or fried, and it was pulling too hard on the ECM if I disconnect 1 injector at a time, would it try to run or throw a code?
Old Jun 7, 2010 | 08:32 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Have not gotten alot of response here. Thought I'd post what I found anyway. It may help others.
Today I pulled injector wires 1 at a time and tried to start. 1, 3, 5, 7 first, then 2, 4, 6, 8. When I got to #8, the car started normally. While idleing, I plugged it back in and the car died immediatly. Go figure. 1 shorted injector killing the whole friggin car. Time to replace then with the Ford 19lb injectors I guess.
Thanks to those who posted to help.
Old Jun 8, 2010 | 03:04 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I did mention above to check injector resistance.
A grounded injector will cause the ECM to shut down the whole injector bank to protect itself
Contact FIC for cheap injectors
http://fuelinjectorconnection.com/shop/
Old Jun 8, 2010 | 12:34 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Cool. Once again, Thank you for the help.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
justin57
Aug 20, 2015 07:05 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
