Running rough, loud knocking
Old Jun 7, 2010 | 07:35 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
For about six months I have been hearing a light ticking in my engine, it is more pronounced when the engine is decelerating after being revved. About three months ago the ticking became more pronounced when driving in gear accelerating, it turned into a knocking sound. However you could only hear the knock when the car was in gear accelerating, at idle if you revved it with the clutch in you couldn't hear the knock.
I drove the car farther than I had in a while, about 10 miles on the freeway, about a month ago, I left it for four days and when I returned I drove home on the freeway and the RPM needle was quivering, it has always been very steady before, but it was quivering and it was not running correctly.
Ever since then the knocking has gotten VERY loud (like a motorcycle when accelerating in gear), it sounds almost as if there's no muffler/cat on the car, the same way it did after I installed my headers and test ran it with no cat/muffler.
I checked the headers and it doesn't feel as if they're separated from the block.
Any ideas? It sounds like two independent problems.
Old Jun 8, 2010 | 05:49 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Running rough, loud knocking
Connecting rod bearing or loose flywheel bolts perhaps.
Old Jun 8, 2010 | 08:05 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
My oil pressure is fine, it's around 35 PSI at idle, don't you think a loose bearing would lower the oil pressure? Especially if it had THAT much clearance as it sounds.
How can I check a loose flywheel bolt? What could have caused that?
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
jbd1969
Aug 17, 2015 07:06 PM
Bradsaundry
Aug 12, 2015 12:34 AM
