another head /cam question
Old Jun 8, 2010 | 06:28 PM
endo666's Avatar
Car: 84 Camaro
Transmission: Stock 5 Speed
Found a set of heads that have had work done to them for $300 the work was done by a local and good machine shop. will be taking my block to the same shop.
casting 8827186
Here is some stuff on the invoice
Valve job &magnaflux
install 16 guides
8x stainless 2.02 in manley 10750
metal viton seals
3/8 rocker stud
$355 worth of work plus the cost of the heads.
Now my question it was also noted that he would be using a Hydraulic roller cam.
should i be able to use a Hydraulic flat tappet cam without having to change anything on the heads.
Lastly is this a good deal?
Old Jun 8, 2010 | 07:10 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: another head /cam question
is this for your 305? If so then no it's a bad idea the compression will be really low.
Either way for the money you are in aftermarket head territory and there's much better choices out there in the price range.
Old Jun 8, 2010 | 07:13 PM
endo666's Avatar
Car: 84 Camaro
sorry no it is for a 350 im building
most aftermarket heads i find are $400 or more un-assembled. am i missing some good cheap aftermarket heads.
Old Jun 8, 2010 | 07:37 PM
Doom86's Avatar
I made that remark assuming 186 heads are still selling well because of the restoration crowd. You couldn't get a set for less then 200$ last i saw but i could be wrong, it's been a while.
So i was assuming 550-600$ total cost on the heads and that's easily Vortec, or RHS, and getting close to some of the budget aluminum head manufactures territory.
Aluminum Patriots are 795$ assembled from Summit and will be a huge upgrade to the 186 casting.
Old Jun 8, 2010 | 08:13 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Speedway Motors is selling some new Chinese 170cc aluminum heads for $550/pr. bare.
Old Jun 8, 2010 | 08:54 PM
endo666's Avatar
Car: 84 Camaro
well i will have to decide what i want to do so should i be able to use these heads with a Hydraulic flat tappet cam without having to change anything on the heads.
Old Jun 8, 2010 | 10:38 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If the springs are too stiff you risk wiping lobes. You really should make sure your springs give less than 100 pounds closed and less than 300 pounds open.
Old Jun 9, 2010 | 07:48 AM
endo666's Avatar
Car: 84 Camaro
sounds good i will give the guy a call and ask what springs he used.
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
