powersteering line
Car: 1990 Camaro RS
Engine: LT1 350 5.7L
Axle/Gears: posi rear end
powersteering line
i got this powersteering line with my lt1 and it was cut from the car. its the pressure hose right?it has a plug on it. for some reason when i search for the right hose on google it dosnt have the plug on it.
Car: check
Engine: check
Transmission: check
Re: powersteering line
By plug, you mean the item at the bottom of the picture? That is the P/S high pressure switch. It will unscrew from the fitting and be threaded into the new line.
RBob.
